The software is compatible between mk1/mk2 tuners. The tuner device just sends commands out over serial instead.
The RDS packets come out of /dev/rds (8 bytes - 4x16 bit error-corrected packets making one RDS frame). The code which decodes the entire frame, saves AF lists, TA flags, etc is already in the player - it's just not completed.
Hugo
