Slipperyness is caused by the heat or pressure on ice, this results in the contact points on the ice and whatever material melting. So what happens is a thin layer of water forms between the tires and the ice and this causes the slipping. If the temperature is low enough then it'll take greater and greater amounts of pressure to melt the contact point :).
Calvin
