No mine was a footer on the cable connection to the board...
You could just barely see that there was a crack in the soldering. So a spot of solder on the board and I was up and running. If that isn't it then you should just contact Patrick for a new cable. You should have it in a couple of days. Also you can try using the other connector on the ide cable.
Michael West
