Ok, here it is. A few quick notes!!
---- This was written for ME, it might not work for you without modifications ----
--- I am using the emplode CSV file for this
--- This currently only reads ID3v1 tags from the local mp3s
---- How to get your CSV into this app
Open the frmImport_CSV form
Type the path to your CSV file in the text box
Click Import
Your empeg database should now reside in a table called Empeg
There is also a table called links that will be created which is a list of FID connections from your empeg. This will allow you to see which songs are associated with certain playlists..
--- How to scan your hard drive for songs
Open the frmImport_Songs form
Type the path you want to scan
Click Import
All of your local music should now be stored in a table called Songs
There are two queries saved that should get you started on synchronizing your playlists.
Please let me know what you think and any suggestions would be appreciated :
http://www.workbuddies.com/music_tracker_1b.zip
----- RioCar 60gb
