Ok, it looks like Emptriv isn't binding to the hijack menu at all. Empacman binds but if you run it, you can't exit and the control buttons don't move Pacman. Emptris binds fine, but if you try to run it, all it does is kick you to a blank screen you can't get out of (it might be doing the same thing as pacman with the buttons not controlling the game, I can't tell because there is no display.) Emptriv won't even bind to the Hijack menu. Help would be greatly appreciated. No erros from the serial port, the hijack just outputs that menu entrys are removed.
