Ok, I've read the FAQ and I've been an Empeg user for a while, but I'm at my wits end with this one.
I have two empegs. Both were 20G units. I ran out of space. I bought a single 40G IBM Travelstar and formatted it. I also formatted one of the 20G drives (also an IBM Travelstar) and moved it to the other player. So now, I have two players: Player A (20G+20G) and Player B (40G).
Both work just dandy on AC power, and I synchronized the data between them using Mirrordir. It took quite a while, but finally finished.
Player A will work in the car just fine (the one with two drives). But player B, although just fine on AC power, shows "NO HARD DISK FOUND - CONTACT SUPPORT" when in the car.
I thought "Hmm, power?" But I don't think so, because the two drive unit (each drive says (5.0V 500mA) works fine, and the single drive unit (which says 5.0V 1A) does not.
Player B does not display any unusual errors on startup (at least on AC power, I don't have a terminal in the car).
What have I done to deserve this? Please Help!
Edited by ClownBurner (07/01/2003 11:39)
_____________
James Mancini
