Cool, thanks for the detailed description. Running it through the compressor with the default settings gets me something that is more pleasent (I can at least understand what the singer is singing throughout the passage). I am going to create a few samples to play through real speakers tomorrow. Is there a correct order to run the filters in (should I adjust EQ before compressing or vice-versa) to avoid discarding bits?
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
