Not bad, assuming you are in the right directory. You should still see a config.ini file. It means that they are not there. They can be rebuilt. Do the steps I stated above, but don't worry about the rm filename steps. Since the files are already deleted, you don't have to worry about that bit.
Paul Grzelak
