but after the spash screen i get the "Empeg screen of death" you know "Hard Disk Not Found, Contact Support" any ideas??
Read through each and every one of the possible causes in that FAQ entry I linked. Any one of those could cause the error you're seeing, so check each one. The most common causes are: Bad cable or cold solder joints on the IDE header.
