bend all the pins ever-so-slightly on the HDD so you get a tighter grip on the cable connector. The pins must obviously remain straight enough to enter its respective 'lead in' chamfer on the cable connector.
Not sure if this method is solid enough to get a FAQ entry, but at least you dont have to start shooting hot glue everywhere
A coward you are, an expert on bulls you are not.
