<bitt-->
yeah, the only one Crutchfield carries that i could find are these Blaupunkts. The specs look a little impressive for the price/size...
150 watts x 2 at 4 ohms
200 watts x 2 at 2 ohms
400 watts x 1 in bridged mode
stereo or bridged mono output
Tri-Way capable
Class "T" amplifier technology
MOSFET power supplies
speaker-level input adapters
50-250 Hz variable high- and low-pass crossovers, 12 dB/octave
selectable subsonic filter at 10 Hz
remote gain control
10"W x 2-5/8"H x 9"D
it's tiny and supposedly gives off little heat. Also says you can take the case off for tight installs... which is very appealing. I'm still not convinced though. Anyone else wanna weigh in on this?
<mark-->
Thanks... now if i can only find a digital amp...
|| loren ||
