Seems to work too well...
No matter whether I had the messages enabled or disabled, I didn't receive a single RDS message on the one station that broadcasts it. I assume from a cursory glance at the patch that you are simply blocking most if not all RDS messages?
Either way that's fine for me (and stops the stupid AF stuff retuning over and over) since I don't need or use the RDS but I'm sure others will complain.
Also, one other thing I noticed. In the menu, I assume you are going for alphabetical order? In my case the Tuner AF Blocking option was appearing before Show Flash Savearea. It took me a while to find it because of this. You can see this in this part of the patch.
@@ -3059,6 +3083,7 @@
{ blankerfuzz_menu_label, blankerfuzz_display, blankerfuzz_move, 0},
{ blanker_menu_label, blanker_display, blanker_move, 0},
{ saveserial_menu_label, saveserial_display, saveserial_move, 0},
+ { tuner_af_blocking_menu_label, tuner_af_blocking_display, tuner_af_blocking_move, 0},
{"Show Flash Savearea", savearea_display, savearea_move, 0},
{ bass_menu_label, bass_display, tone_move, 0},
{ treble_menu_label, treble_display, tone_move, 0},
BTW: I am in Australia.
Thanks,
