Hi All;
I'm a little bit concerned that the Network chip is busted on my empeg. I've checked the cable, and the hub, they both work fine. The link LED lights up as it should, but when it tries to lease an IP address I get the following error from my dhcpd server:
ip length 576 disagrees with bytes received 1486.
accepting packet with data after udp payload.
DHCPDISCOVER from 00:02:d7:28:10:c3 via eth0
DHCPOFFER on 192.168.1.20 to 00:02:d7:28:10:c3 via eth0
This is repeated once every 2-3 seconds. I assume this is because the empeg is constantly trying to get an ip address.
Does anyone know what the problem could be?
Thanks in advance,
Bryan
