Different drive geometries. The number is in cylinders. To get the usable space, you need to multiply the number of cylinders for each partition by the number of blocks per cylinder (16065 in your case, 1008 in Peter's case). This will give you the number of blocks (1/2k) per partition.
Edit: Or just look under the block count... I am not doing well with this today...
Edited by pgrzelak (15/07/2003 10:17)
Paul Grzelak
