OK, here is the info from a sync. I am including the info from a reboot as well in an attached text file for anyone who wants to see it. Unfortunately with my current knowledge level the only thing I noticed was that I have some bad tags. I guess this might also account for why it seems to take longer to boot. I was passing that off as just my imagination.
Adding Swap: 16596k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
hda: read_intr: status=0x59
hda: read_intr: error=0x40
end_request: I/O error, dev 03:03 (hda), sector 4882
end_request: I/O error, dev 03:03 (hda), sector 4884
! playerdb.cpp : 182:Failed to build dynamic database (status=0xc004401a).
Hijack: intercepting config.ini
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4086d000
169865-Riocarboot.txt (199 downloads)
Daniel [blue] 10G MkIIa [/blue] Quantum Mechanics: The Dreams Stuff are made of.
