There may in fact be a stealth floppy drive disabling setting in the BIOS, called "Swap FD" or something similar. This inverts the drive select line, so A: becomes B:. It's a sneaky setting that can cause hours of enjoyment if it gets turned on, by, for instance, a CMOS backup battery getting low and causing the BIOS settings to become a bit suspect.
