You didn't say anything about price. If you don't mind spending big bucks, you can get a nice plasma TV that fits your criteria. You can spend the least money buying a traditional three-gun CRT rear-projection set. There are also newer rear projectors based on DLP or LCD mechanisms (basically, the same gear as a DLP or LCD front-projector, but built into a box with a mirror and a big screen).
If you find a DLP or LCD-based rear projector that you like, and it's a similar price to the CRT projector, I'd probably prefer the DLP or LCD. The main benefits are you never have to converge the thing or worry about burn-in. The main flaw is you occasionally need to replace the expensive bulb.
