I like the info-line display with a smooth visual in the background but whenever the empeg is shut down I have to reselect the info displayed. That's kind of boring.
This is a bug. It will be fixed in 1.01. Right now, if your last visual was info:line, holding the bottom button goes back to info:none instead of info:line. It's supposed to go back to info:line (and it does this correctly in the alpha preview of 1.01 that I'm testing).
Other than that, the unit already does what you're asking it to do if you press and hold the bottom button. See the FAQ item on this subject.
___________
