Back in June I was having a problem with no/low right channel volume.Seems the problem is back.I Swapped the rca cables from left to right and the problem switched so i'm pretty sure the problem is with the player.I also tried the rear rca's and the home 1volt rca's and the problem was duplicated.
I haven't contacted support yet,just wanted to see if anyone else had this occur.
With my very limited electronics experience I am going to guess that it has something to do with the audio output components.If that's the case,would those parts be available locally(USA) or are they something special only from Empeg.
MIKE 80Gb RIO
