OK, I've taken the top off, and I can't see any damage to the VFD nipple - even the little end bobble of glass that's quite close to the Pulsing LED of Power is untouched. I can't see any damage to the display cable either, but I haven't taken the hard drive tray off and had a really close look. There is a scorch mark near the bottom right-hand corner of the VFD, though, near a wire or component that comes up close to the glass. Is this normal? (I don't know, I've never taken the front off before.
I've yet to test its response to serial commands, and as it's a Mark I I can't telnet into it or similar. The log of the serial session is:
empeg-car v0.04 19990121 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux........................... done, booting the kernel.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v336 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed May 28 20:10:44 EDT 2003
Processor: Intel StrongARM-1100 revision 9
empeg-car player (hardware revision 4, serial number 00061)
Command line: mem=8m
Memory: 7228k/8M available (676k code, 20k reserved, 264k data, 4k init)
Dentry hash table entries: 1024 (order 1, 8k)
Buffer cache hash table entries: 8192 (order 3, 32k)
Page cache hash table entries: 2048 (order 1, 8k)
Linux NET4.0 for Linux 2.2
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Forced DC/Car mode
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button support initialised (Using FIQs).
empeg usb initialised, USBN9602 revision 1
empeg state support initialised 0089/8893 (save to d0005680).
empeg RDS driver initialised
empeg power state driver initialised
Linux video capture interface: v1.00
empeg FM radio driver (Philips).
empeg dual channel IDE
Probing primary interface...
No drives found, retrying...
hda: TOSHIBA MK4019GAX, ATA DISK drive
Registering drives...
ide0 at 0x040-0x047,0x078 on irq 7
hda: TOSHIBA MK4019GAX, 38154MB w/0kB Cache, CHS=4864/255/63
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Tried to mount /dev/hdc4 but got error 15
No secondary hard disk
Starting player
Hijack: intercepting config.ini
Does that give any clues? I'll search riocar.org for a list of the serial commands later - now I've got to go to work (with no music - aaaararhhhghghghhgh!)
Thanks in advance,
Paul
Owner of Mark I empeg 00061, now better than ever - (Thanks, Rod!) - and Karma 3930000004550
