I've been praying for him to add genre and year into the tags of files downloaded through Jemplode... Seems like an easy fix...?
The nice thing about open source is you can fix things yourself rather than spend all your time praying for them
Even if the original author is busy with something else. Find jemplode.jar on your hard drive and replace it with
this version which should fix the genre/year bug (you may need to use GetRight or something like that to keep your browser from mangling the file).
-Mike
p.s. The actual bug is in the (closed source) id3library jemplode uses, but there is a simple enough workaround. The updated EmplodeSyncManager.java is
here.
