then you need to connect the AUX ground to the car ground; it's designed to connect to other in-car components which share a common ground.
Hugo, can you elaborate a bit on this?
I have been unhappy with the results of my portable CD player feeding into the auxilliary input of the empeg, because when I turn the gain down on the portable player the floor noise (sounds like a 60-cycle hum) becomes quite noticeable, particularly if I am running the portable player by means of its AC power brick instead of on batteries.
How do I connect the AUX ground to the car ground? Am I supposed to somehow ground the portable player as well?
I apologize if these are silly questions, but as you know by now, I am not all that technically inclined.
