Greetings!
Does the XM have any inputs? Otherwise, you may need to run the XM via IP-BUS to your radio, and then your radio to the car player's inputs. You would need to rewire / get an amp for that configuration.
The problem sounds like the Pioneer will accept either the IP-BUS or RCA in, but not both at the same time. You need either two inputs into the radio, a switch or you need to daisy chain all three devices in series.
Does your XM radio have an RCA out? Perhaps an RCA switch on the input of your Pioneer...
Paul Grzelak
