It also sounded like you're running multiple monitors. Is that feature added by some special third-party software trick, or is it with the normal Windows 2000 support for multiple monitors?
In other words, when you get the display properties, do you see two monitors, labeled 1 and 2, in the regular Windows display properties screen? Or do you need to run a third-party utility to adjust your dual monitor settings?
