#200390 - 26/01/2004 16:50
Re: Hijack v360
[Re: tonyc]
Loc: Providence, RI
And after you finish that (or before, if you like) I could sure use a vfdlib_drawBitmapScaled() function that can display a vfdlib bitmap, scaling it to user-supplied dimensions. I've had no luck finding an appropriate image scaling algorithm, and my attempts to use the GD library to do it resulted in (as expected) very poor performance.
Probably after. The code for the tuner injection stuff is mostly done but needs cleanup; The real thing holding up this project is that after the last car was totalled the new vehicle's empeg install resulted in no antenna being connected to the tuner, despite what was otherwise a much nicer install. So, I either have to take the minivan (the one I had in Ohio in 2002) out to test or open the dash in the Neon, and with the crappy weather neither has happened. It's a shame, because I think tunermon works otherwise already, it just can't change what channel is being monitored.
Hijack v356, v357, v358, v359, and soon.. v360
Re: Hijack v356, v357, v358, v359, and soon.. v360
foxtrot_xray
25/01/2004 14:48
SE_Sport_Driver
25/01/2004 15:01
SE_Sport_Driver
25/01/2004 14:49
Hijack v360
Re: Hijack v360
Re: Hijack v360
Daria
25/01/2004 17:51
Re: Hijack v360
Re: Hijack v360
SE_Sport_Driver
25/01/2004 18:36
Re: Hijack v360
Re: Hijack v360
Daria
25/01/2004 23:16
Re: Hijack v360
Re: Hijack v360
Daria
26/01/2004 16:50
Re: Hijack v360
Re: Hijack v360
Re: Hijack v360
Re: Hijack v360
Re: Hijack v360
speedy67
30/01/2004 18:23
ShadowMan
26/01/2004 07:10
pgrzelak
26/01/2004 07:36
TigerJimmy
26/01/2004 10:00
paulj
26/01/2004 15:39
Daria
26/01/2004 16:33
SE_Sport_Driver
26/01/2004 16:47
Mataglap
26/01/2004 17:01
