This is my first alpha install so please take it easy on me.
I've installed v3A7 using the Rio Upgrade Wizard, after replacing emplode with the alpha version 2.10 (I renamed the old emplode and put the two new files in its place in my c:\Program Files\Rio\emplode folder). That seemed to work, the player boots up to A7 no problem.
The problem comes when I run emplode (the version from the Alpha download site). When I try to sync after making changes emplode exits with extreme prejudice. Someimes this leaves the empeg 'synchronizing', sometimes not.
"Synchronize failed while restarting the player. An established connection was aborted by the software in your host machine. (error 0x80072745)"
The empeg reboots and I'm returned to emplode (doesn't crash).
Any ideas what I've done wrong? The Readme.txt says:
You should install the new emplode before installing this release. If you fail to do so your empeg-car unit may not function and it will be necessary to apply the upgrade again using the correct version of empegUpgrade or upgclient.
I'm thinking that I can't apply the alpha from a windows platform?
Help!
-Zeke
WWFSMD?
