I just got our new 515E into the shop and I've been trying to get it up and running. This is my first experience with PIX, so I've definitely drifted a little deeper in the pool than I've been before.
We have a subnetted class C that we'd like to hold on to, since all the machines are presently configured with it. I'm not interested in NAT and using private addresses behind the PIX since that is the case. I can't seem to get the unit configured, though, in such a way that it let's me access outside from inside.
Using the example here:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/config/bafwcfg.htm#39502
I managed to work up the following config:
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname pixfirewall
domain-name mysite.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list acl_out permit icmp any any
pager lines 24
logging buffered debugging
mtu outside 1500
mtu inside 1500
ip address outside A.B.C.130 255.255.255.192
ip address inside A.B.C.193 255.255.255.192
ip audit info action alarm
ip audit attack action alarm
arp timeout 14400
nat (inside) 0 A.B.C.130 255.255.255.255 0 0
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 A.B.C.129 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http A.B.C.200 255.255.255.255 inside
floodguard enable
telnet timeout 5
console timeout 0
terminal width 80
I can ping the router (outside) from the PIX, and I can ping hosts on my network (inside) from the PIX, and vice versa. I can't seem to transverse it, though, with ping or http requests.
Anyone see the problem with my configuration?
- Edited because I'm an idiot.
