Hi,
I have a playlist that contains the following sub-lists: Hair, Pink Floyd, The Doors, The London Philharmonic Orchestra (really, I do). Let's say I currently have Hair highlighted. I do the following: press the right button on the player, quickly followed by the bottom button (obviously expecting to enter the Pink Floyd playlist). Here is what actually happens:
1. Hair stops being highlighted and the menu starts shifting to the right.
2. Before it fully reaches Pink Floyd, it enters Hair.
3. The original playlist moves one level up and is now partially obscured by the new playlist, but continues to shift until it reaches Pink Floyd.
4. If I now press the top button, I end up with Pink Floyd highlighted.
In a sense, both button presses got handled in parallel. Not what I intended, though...
Here is a screen capture of this behaviour (forgot to make it loop, so you'll have to refresh the page if you want to see it again):
Borislav
