OK, I could make it in aircraft-grade aluminum, about 50mm long, the top spigot being perhaps 20mm diameter x 20mm long, the cone widest point being about 45mm. The hole in the end tapped 5/8 UNC (same as 5/8 whitworth, for all intents), the three mounting holes M4. That do you?
