OK, thanks. It's at home now and I'm not. I'll check the boot logs for the CS4132A problem and look at the solder joints. I can rule out most of the other causes for now.
Is there a disk checking utility I can use to check the drives while in the empeg? I don't have any other computers that I can connect laptop drives to.
On a side note, my DirecTiVo HDD died this weekend, got that successfully replaced and upgraded to 205 hours, and preserved recordings. I used Maxtor Powermax to determine which drive is going bad, but I replaced both. I hope my HDDs in the empeg aren't dying...
Dave Clark Georgetown, Texas MK2A 42Gb - AnoFace - Smoke Lens - Dead Tuner - Sirius Radio on AUX
