A little back story, Stu is currently upgrading Nanci (who was on loan to Filener Laser as a tester). I forwarded rivets and 2 fans to him (one mouser and one farnell). The rivets should be Farnell part 722-4321 but I didn't double check when I received them.
Instead of installing the 5V fan as recommend by PCA in the FAQ, we went with a 12V Mouser fan. There was some concern that a fan would generate noise if connected to the same 5V header as the digital out board. Unfortunately, the rivets do not appear to be compatible. I suggested using silicone gasket adhesive to glue the fan but Stu tells me that the silicone can cause problems with the electronics. This is how I affixed the fan in my other player so I'll need to find another solution for Jolene also.
