There's actually one catch, though, which I discovered last night. Files encoded by ripping directly off the CD from the command line get a "click" in them at the beginning, because apparently LAME doesn't deal properly with the AIFF-C header when it's told to byte-swap, so it assumes that header is sound. Converting the files to normal AIFF with SoundApp (in Classic), and then converting the AIFF's using LAME, works fine, however.
Daniel M. Zimmerman, Caltech Computer Science
Mk.2 #060000058, 36GB
Mk.1 #00101, 10GB
Daniel M. Zimmerman
Mk.1 #00101, 10GB
