This afternoon I was playing random songs from a playlist when a song started glitching and freezing for a few seconds then restart only to freeze momentarily again. I thought it was a bad track so I started the next song and the problem kept happening. I finally turned the power off and rebooted. No problems since. I thought about opening up the unit to see if a hard drive cable may have come loose, I moved it in the car from a friends house after a party a few weeks ago, but I never got around to actually opening it. If it does it again I will open it.
BTW, the Central worked flawlessly as party audio device. With the larger screen you can see it when you are really inebriated...
Sean in NC
