hi, the last week i've installed a new 60GB HITACHI Travelstar Hard Disk side by side my existing 20GB IBM Travelstar. Because of the software and the configurations present in the previous 20GB HD system, i've installed the new one as slave thoughtfully following the F.A.Q. over riocar.org. Everything seems to go smooth uploading new tunes (i've uploaded 10GB of new tunes without problems, i can play it) but i've problems uploading playlists, in other words, when i sync after altering a tune/playlist name, position or info, emplode freezes when "Uploading playlists...". If i wait (10-15 mins) it says in warnings: "Initializing Massive Attack could not be synchronized, Connection timed out (error 0x8004003e)" with Massive Attack as example of playlist altered. I've to say that i don't have this error all the times, but in 70-80% of playlist sync. I'm using Alpha 7 software, Hijack 395 and Emplode 2.0, i've got the same problem with Emplode 2.10 and i've also used the fidsift.sh script without success. I've this error in serial console every time i sync:
Adding Swap: 16596k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
hdc4 is mounted.
but i don't know how to solve it. Do you think is the cause of the sync problem ? Ideas for a solution ? Thank you very very much.
shapeless
MK2a | #010101588 | 2x 120GB SSD | Hijack v526 | v3.0a11 | > melpomene <
MK2 | #090000581 | 60 & 100GB HD | v2final.mk2 | v2.01 | > backup <
radio | all colors lens | greenlights LBSSK buttons | KCA-R6A + ERC-1A remotes | carry cases | empeg sticker!
