Do you know if there is some sort of file size limitation on the database? I have a music share with 114 gigs between 24,604 files. For some reason, xplrionet is missing portions of the collection, even if I do a purge and scan. It took me a while to notice because it seems to have quite a bit in it, but I had a frend requesting things we found via the file share, but not on the web interface or via the player.
Also, what is needed to get the TTS to work? I installed the xplrionettts, lame.exe into the cache folder, xplhal, and the MS Speech SDK 5.1 (that seemed to kill the TTS control panel in XP...) and I do have it enabled and running.
