Unfortunately, it looks like your bootlegged tracks don't correctly null-terminate the comment, so Mike's code picks the whole thing up as the comment.
Actually, that wasn't the case. The Comment fields were full of nulls, 29 nulls followed by the track number. They were correct. Note that I tagged the files myself. The tracks may have been bootlegs, but I always make sure my tags are right.
However, it would be conceivable that a comment might naturally have a single quote in it, in which case, you're still broken.
Exactly. We're trying to find if the problem is on the Central itself, or if it's only in Jemplode. If the latter, it's a bug fix. If the former, since no bugfixes are going to happen there, then we need to implement a work around in both emplode and jemplode.
