D*oh...
here it is:
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Wed Feb 19 21:53:19 EST 2003
empeg-car player (hardware revision 7, serial number 80000456)
Command line: mem=12m
Memory: 10940k/12M available (996k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-218000, ATA DISK drive
hda: IBM-DARA-218000, 17301MB w/418kB Cache, CHS=35152/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:c8
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
change_root: old root has d_count Trying to unmount old root ... okay
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
hijack_do_execve: execve() failed, errno = 2
hijack_exec("/programs0/empacman"), rc=-2 (ERROR)
hijack_exec("/bin/bash -c "/usr/local/bin/start_empire 10 &""), rc=0 (okay)
khttpd: listening on port 80
kftpd: listening on port 21
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin# / ./player -i
bash(12): memory violation at pc=0x02033000, lr=0x00000000 (bad address=0x00000000, code 2)
pc : [<02033000>] lr : [<00000000>]
sp : bffffe5c ip : bffffe70 fp : bffffe6c
r10: 40155128 r9 : 0200fbd0 r8 : 0207bc58
r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 02084380
r3 : 00000000 r2 : 00000000 r1 : 00000035 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: D038117D Table: D038117D DAC: 00000015
Function entered at [<02012054>] from [<020121b0>]
r4 = 00000000
Function entered at [<020120fc>] from [<02011e78>]
r8 = 0206459C r7 = 0200F224 r6 = 0207BC80 r5 = 00000001
r4 = 00000000
Function entered at [<02011d44>] from [<0201041c>]
r5 = 00000000 r4 = 02080F38
Function entered at [<0200fbd0>] from [<4008d040>]
r6 = 4000C2A8 r5 = 00000001 r4 = BFFFFF24
Function entered at [<4008cee4>] from [<0200fb40>]
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 00000000
r6 = 0200FB1C r5 = 00000000 r4 = 4001E5EC
Shell exit
Starting player
Vcb: 0x4054d000
[27] player: old system call.
Function entered at [<5f5f3625>] from [<00006f66>]
Unable to handle kernel paging request at virtual address 5f5f3629
memmap = D0380000, pgd = c0b80000
*pgd = 00000000, *pmd = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c00e5de0>] lr : [<c0019710>]
sp : c0383f88 ip : c0383f44 fp : c0383fb0
r10: 00000008 r9 : 00000001 r8 : 0000000c
r7 : 00000000 r6 : 5f5f3625 r5 : 7079745f r4 : 021233e4
r3 : 60000013 r2 : c01061e4 r1 : 00000001 r0 : 021233d4
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Process player (pid: 27, stackpage=c0383000)
Stack:
c0383f60: c0019710 c00e5de0
c0383f80: 60000013 ffffffff c0383fb8 0214f0c0 00cf3731 40000013 c0383ff4 c0010810
c0383fa0: 021233bc 00000000 c0383fb4 c000a0a4 c0010790 021233bc 021549d8 00000001
c0383fc0: 00000008 021549d8 021233bc 0214f0c0 021233d0 0214f0f0 02152f98 00000001
c0383fe0: 00000008 021233e4 0214d744 0214f0d0 0207d924 021233fc 20000010 021549d8
Backtrace:
Function entered at [<c0010784>] from [<c000a0a4>]
r4 = 021233BC
CoRestored terminal settings
Player received signal 11
Starting bash.
empeg:/empeg/bin#
