![Unoffical empeg BBS](/logo.gif)
#230195 - 09/08/2004 12:11
Re: emplode doesn't recognize player
[Re: Roger]
Assuming that you did, you should also check that the empeg was correctly recognised by your OS. For example, on Windows XP, go to Control Panel / System (if you're not in Classic View, it's under Performance and Maintenance).
On the Hardware tab, click on Device Manager. Scroll down to the bottom and open the Universal Serial Bus controllers item. There should be an entry labelled "SONICblue Rio Car". If not, you don't have the USB driver installed correctly.
You'll need to have the empeg plugged in and turned on for this first.
It does have SONICblue rio car in the USB controller. So the drivers I got MUST be fresh. Still the freakin' software won't recognize the player, and that's some frustrating crap to take...Are there any bypasses? Is there any way I could just crack open the damn box, extract the harddrive, connect a wire to it and get all of the files out of it???
Edited by mcsimuss (09/08/2004 12:14)
