Since Mark brought it up
here, I guess now is as good a time as any to mention my Mk2 is not recognizing the extra 4 MB Stu installed several months ago.
I honestly don't
need the extra memory; I'm still running the original 10GB hard drive
. But I recently installed emphatic and having some extra cache would be nice. The boot log and Ctrl-T memory diagnostic results are below, let me know what else is required.
Edit to add: running 2.00 final developer and Hijack v410.
e000 v1.04
Copying kernel...
Calling linux kernel...time reached, running e
em
l.-p
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v410 ([email protected]) (gcc versioning to unmount old root ... okay
2.95.3 20010315 (release)) #2 We
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.iserfs but got error 19
empeg-car player (hardware revision 7, serial number 90000980) 12MB DRAMd to mount /dev/hdc4 but got error 6
Command line: mem=12mrtitions (possibly al
Remounting first
Memory: 10952k/12M available (984k code, 20k reserved, 328k data, 4k init)ting second music partition read-only
Press 'q' now to go into development mode
hijack: remove
khttpd: listening on
kftpd: listening on port 21
IP Protocols: ICMP, UDP, TCPg non-standard cache size 74
player.cpp : 385:empeg-car 2.00 2
Prolux 4 empeg car - 2.1434 Mar
Starting kswapd v 1.5
SA1100 serial driver version 4.27 with no serial options enabled (priority -1)
e2fsc
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UAR
empeg dsp audio initialised
Starting pl
empeg dsp mixer initialised: US/Pacific
empeg dsp initialisedting config.ini
empeg audio-in initialised, CS4231A revision a0che size 74 (adjustment 10)
empeg remote control/panel button initialised. : 385:empeg-car 2.00 2003/04/01.
empeg usb initialised, PDIUSBD12 id 1012Prolux 4 empeg car - 2.1434 Mar 26 2003
empeg state support initialised 0089/88c1 (save to d0004680).
ÿIf there is anyone present who wants to upgrade the
empeg RDS driver initialised
Probing primary interface...
Calling linu
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, ATA DISK driveting the kerne
l.
hda: IBM-DJSA-210, ATA DISK driveeg52-hijack-v410 ([email protected])
hda: IBM-DJSA-210, ATA DISK drive010315 (release)) #2 Wed Aug 4 00
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
Checking for extra DRA
empeg-flash driver initialized0000: wrote ffffffff, read ef1
smc chip id/revision 0x3349
NetWinder
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected]
RAMDISK: ext2 filesystem found at block 0served, 328k data, 4k init)
EXT2-fs warning: checktime reached, running e2fsck is recommended: 16384 (order 4, 64k)
VFS: Mounted root (ext2 filesystem).ies: 4096 (order 2, 16k)
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
Timezone: US/Pacific
Hijack: intercepting config.ini
opening display...
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
Using non-standard cache size 74 (adjustment 10)
emphatic v2.04 (built Aug 17 2004 21:05:49) running as pid 12
Vcb: 0x404ad000
Also, here is the memory test diagnostic results:
empeg-car bootstrap v1.00 20000601 ([email protected])
0140 testing ic 4 (4-7mb, high word)
0150 testing ic 19 (8-11mb, low word)
0160 testing ic 32 (8-11mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id IBM-DJSA-210
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 38
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
