One other thing to try.
Yeah, what he said: leave the computer plugged into the router and connect the Receiver to the router via a cheap hub -- i.e. the Receiver goes into one port, and the hub's uplink port goes to the router.
It looks like the Receiver's not getting an IP address from your DHCP server. I assume that you're using a DHCP server provided by your router?
The other thing we normally check is that the Receiver's getting Ethernet (as opposed to PNA) link. Can you include _all_ of the text from the screen of the Receiver with a failed boot? Which lights are lit on the back of the Receiver?
roger
