Damn! Check your local Cash Converters too, you never know.
Will your insurance cover the replacement costs?
Also make sure you double your security - apparently it is fairly common for the b'stards to return and have a second go. If they busted a lock/frame the best method is a steel bar screwed down the edges of the door and frame. "London" bar I think it's called.
Gareth
