Greetings!
The first thing is to verify that the empeg is completely seated in the sled. That is the question about the bent sled. If it is a wiring issue, there are ways the sled can be removed easily, usually with a thin metal strip inserted on each side to push the bent tabs back into place.
Paul Grzelak
