I got to looking at the FAQ and seen the different ways to wire it.
Ah, good, before I had to point you there.
It's a matter of preference. If you don't have a remote level control for that bazooka, then you can choose to either fade between your fronts and rears, or choose to fade between your speakers and your sub.
The choice is entirely up to you and you can alter that layout however you like if the amp is mounted near the sub.
