#243348 - 08/12/2004 03:28
Re: empeg not holding settings, please help!!!
[Re: schofiel]
Quote: More useful: blow V2 Developer. From the command line discard the current playlist and start the player from scratch with "player -i" (see the FAQ for this). Then reboot, connect with emplode, change one single piece of data, then do a sync.
Sorry but I do not understand what you mean by "blow v2 developer", I searched the FAQ for this and "player -i" with no results. The boot messages look normal but here is what I received when I captured three complete boots with Hyperterminal.
empeg-car bootstrap v1.02 20001106 ([email protected]) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #12 Tue Apr 1 18:51:41 BST 2003 Processor: Intel StrongARM-1100 revision 11 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 120001063) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 206f6972 'rio ' empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004100). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive hda: IBM-DARA-212000, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 serial_notify_thread.cpp: 116:@@ N0 serial_notify_thread.cpp: 117:@@ F0x14e0 serial_notify_thread.cpp: 118:@@ TBamboo serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 180:@@ #0 0:00:00 serial_notify_thread.cpp: 170:@@ S0
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memo player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 serial_notify_thread.cpp: 116:@@ N0 serial_notify_thread.cpp: 117:@@ F0x14e0 serial_notify_thread.cpp: 118:@@ TBamboo serial_notify_thread.cpp: 119:@@ AJoe Satriani serial_notify_thread.cpp: 120:@@ GOther serial_notify_thread.cpp: 180:@@ #14e0 0:00:00
farmtech
05/12/2004 15:17
farmtech
05/12/2004 17:58
farmtech
05/12/2004 21:20
genixia
06/12/2004 18:09
farmtech
06/12/2004 23:52
farmtech
07/12/2004 00:58
genixia
07/12/2004 02:52
farmtech
07/12/2004 12:36
genixia
07/12/2004 14:35
schofiel
07/12/2004 14:15
farmtech
07/12/2004 14:34
schofiel
07/12/2004 20:11
farmtech
08/12/2004 03:28
genixia
08/12/2004 04:48
farmtech
08/12/2004 12:09
schofiel
09/12/2004 05:59
farmtech
09/12/2004 12:38
farmtech
09/12/2004 23:12
genixia
09/12/2004 23:50
farmtech
10/12/2004 00:06
genixia
10/12/2004 00:13
farmtech
10/12/2004 00:38
genixia
10/12/2004 03:39
farmtech
10/12/2004 01:54
schofiel
10/12/2004 11:03
farmtech
10/12/2004 11:59
genixia
10/12/2004 17:22
farmtech
10/12/2004 22:18
genixia
11/12/2004 02:40
farmtech
13/12/2004 01:44
genixia
13/12/2004 02:51
schofiel
13/12/2004 21:19
farmtech
14/12/2004 15:31
schofiel
14/12/2004 22:57
genixia
15/12/2004 19:04
farmtech
15/12/2004 19:42
