I posted a couple of days ago to see if anybody had any information on the linksys WET52G, no response - also I've managed to confirm that the version 2 (which I need is not available in the UK), so....
Anybody here use the D-Link DWL-G810? If so, if you're running the 2.15 firmware can you confirm that it supports WPA with radius authentication (i.e you can upload a root & client certificate to it)?
The D-Link site simply mentions in the firmware section that WPA was added, but they've not updated the manuals, so I can't tell if it's actually supported properly or not!
These models seem quite popular, so I'm hoping somebody here will be able to check this!
I'd appreciate this a lot!
Thanks.
Adrian
