Actually, I've been reading the sveasoft forums and it doesn't seem entirely clear as to whether or not it'll do what I want, and I can't ask on their forum because it's locked unless you subscribe to the firmware!
Firstly, their client mode seems to run in NAT mode, which is not what I ideally want, I want it to just clone the MAC address and pass on all the packets.
Secondly it would also appear that WPA support in client mode is somewhat sketchy, the implication is that it might work, it might not!
Thirdly, I can't find any reference to uploading root & client certificates when running in "client mode", I need to do radius authentication (with WPA), so the ability to do this is an absolute must!
Looks like it's close, but no cigar. Dignan, can you see any references to uploading root & client certificates in client mode in the firmware?
And with regards to DWL-810+, this actually appears to be a cut down version of the 810 (despite the fact it has a value adding '+' in the name!) that doesn't support WPA, whereas the standard 810 does.
Thanks.
Adrian
