#244048 - 15/12/2004 13:37
Re: Defragging
Quote: Here's a screen shot
Man, that's some fragmented disk. Basically, you've got the following problems:
- The graph shows less free disk space than Windows is reporting. This is simply a problem with rounding. Each one of those vertical stripes refers to several sectors(*). I'm guessing that if any of the sectors it's referring to contain fragments, then it's coloured red. So, even if it's showing 10 sectors and 9 of them are free, but the other contains a file fragment, it'll be coloured red. This is where your missing space is hiding.
- Defrag will ignore deleted files when moving things around. Any space they're living in will just get overwritten if it needs to put a file there. This doesn't apply (obviously) to files in the Recycle Bin.
- Windows defrag really sucks if you've got a disk that badly fragmented. When it talks about 10% free disk, it really wants contiguous free space. Some of the other defragmenters do a better job in a tight space.
So, to summarise: don't worry about the discrepancy in the space reports; delete some files to make more room (or move them somewhere else temporarily); run defrag lots more times.
Or buy a bigger disk, of course.
(*) Probably not actually real sectors, but my point's the same.
