this time the syncs would fail at stage 6 with the error "file not Found".
Bug found and fixed.
If you've got lots of stuff in unattached items due to a bad sync then it is still possible to get disk full errors during synchronisation since emplode won't be able to resync the unattached items playlist to disk. It is now (since above bug fix) possible to delete stuff from playlists since files are allowed to stay the same size or get smaller when synchronising to a full disk.
Also, emplode wasn't necessarily deleting everything before attempting to write stuff so even if enough space was freed up things might have been done in the wrong order so you'd still get a disk full error. This has also been fixed.
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
