It sounds like everything worked well. It was probably a brand new hard drive - the builder would have asked for a keystroke if it had been already been "built". Try putting a test track or two on. If that works, you are ok. If you run into trouble you might need to rerun the builder a second time (known bug / glitch).
Paul Grzelak
