I' m having some problems getting JEmplode to find the empeg. The only time it seems to work is when the empeg can be found via the default route.
I'm working from a laptop with 2 nic's. One wireless that connects to the internet via a cordless modem. I need the default route to point to that modem as a gateway.
The second is used with a crossover cable connected to the empeg. Even though I can ping the empeg via this nic, JEmplode won't/can't find it via the specific address.
If I change the default route to use the wired nic, the empeg is found but access to the internet is deflected also.
Is my problem with JEmplode or is my routing just not quite right yet?
ps. even with the default route pointing out the wired nic, the empeg cannot be found using a specific address.
